- Feb 22, 2013
- 2
This is a Select Machine horizontal mill model UF, 1970's Taiwan vintage. There is no info anywhere. It is an NMTB 40 taper head.
The vertical head engages via key slot which I thought was the drive dogs on the arbor since they are the same width, but they do not project far enough into the head to engage. So either there was an tool holder that had a key, or the drive dogs were taken off and a larger key was bolted on.
Has anyone seen a design like this? Any thoughts to the best approach?
Is just a tall key good enough, or does it need to mate with the key and back of the drive with an arbor on a holder?
Thanks
Mark
Thanks
Mark
