- Jul 21, 2013
- 16
It's been a while since I posted in the forum but I just picked up a machine that I'm having a hard time finding much, if any, information on. Please bear with me as I only used a mill a small amount in a basic machining class.
It's a Select Machine Tool Co, 6x26" vertical knee mill.
It appears to be a super simple version of a Clausing 8520.
I have a few questions that I hope someone here can answer.
1) What are the correct length belts? (I matched up what was on the machine but one definitely seems too short.)
2) The way cover is also missing. What can I use to replace it?
3) There is only an on/off switch located on the side of the column. Eventually I would like to be able to reverse directions of the motor if I want. Is there a control I can find/buy to let me do that?
Here are a few pics of the machine...
Thank you for any help and information.
Later, Doug
Later, Doug
