- Feb 2, 2013
- 3,622
thank you very much for the information and your recommendation.I have mistakenly feed on the forward stroke , you can get away with it sometimes but if you get in tough to machine steel and the cut gets progressively larger as stroke continues you can get into trouble real quick. On a little shaper I want everything singing like a sewing machine, seems like all the little machines were built to a price point and there are weak links, I sure don't want to bust one up for some foolish move. In my experience on the few machines I have been around while operating you want to hear the ratchet sound on forward stroke and the silence on return stroke. When machine is running fast sometimes its hard to differentiate. To ease my confused state I have taken a dial indicator on a Noga holder and set up to see table advancement to make sure I got it right.
cheers
michael
your help dramatically improved the surface finish.
I think I've heard of cutting on the pull stroke when doing key ways. And then it was cutting on the top of the bore. Haven't tried it.
Greg
Thanks Greg, for reading and commenting- i haven't tried it either
maybe an upcoming project???
i saw stefan gotswinter on youtube using the pull stroke, but as Bob korves mentioned earlier.
the clapper is hinged at the bottom,
instead of at the (conventional) top of the clapper, when you use the pull stroke.
