Sharp tooling?
Firstgear
H-M Supporter - Gold Member
Dec 7, 2018
605
There comes a time in a tools life that it isn’t as sharp as it should be...
1. How do you know to stop using it?
2. What do you do to get them back into usable shape?
JimDawson
Global Moderator
Staff member
H-M Platinum Supporter
Feb 8, 2014
9,367
Normally when the tool quits adequately performing its intended function. This could be leaving an excessive burr, bad finish, using more power than would be expected.
Normally tools are sharpened by grinding and/or honing. In many cases this can be done on a bench grinder and hand stoning, or may require dedicated sharpening machinery which would be the case for endmills and reamers.
P. Waller
Brass
Former Member
Mar 10, 2018
921
It depends on what you consider "sharp".
Much lathe tooling for steel is not what many hobbyists would consider sharp, as in a knife edge.
When a tool stops producing the desired surface finish and dimensions then it is time for a new one.
This is a new insert for steel, I use these often and they produce a very nice finish and last a very long time.
It is very dull as far as knife edges go by design.
Not the nose radius but the actual cutting edge has a small radius of .001-.004" depending on its intended purpose. Knife sharp tools will not last long.
savarin
Aug 22, 2012
2,441
I give my tool bits a quick hone with a fine diamond hone before use and sometimes during the work envelope if I think it needs it.
AdBlock Detected
I've Disabled AdBlock
