R
Robert LaLonde
Forum Guest
Register Today
I need to polish up some steel parts. I grew up sharpening knives (among many other chores) in our family's country grocery store. We had a really nice triple stone I learned to use with which I could put a tomato peeling razor edge or a bone chopping hatchet edge. No stropping required, and if you had to put a steel to my blade it was because you abused it or used it for the wrong purpose. To be fair I could steel a fine edge to save a trip to the stones, but most people do a lot more damage than good with a steel. Anyway, We always used mineral oil on our stones. Plain old mineral oil from the HBA aisle in the store. I thought it worked great. I still use it today for finishing a blade on the stone (I have a nice long tri stone setup in my shop), although I rarely use the coarse stones any more. I tend to reshape a badly abused blade on the bench sander. Its just so much faster if you are careful not to overheat the tip. Now I have seen the various tiny little cans of over priced oil sold private labeled for "arkansas stones," and I tried it a long time ago. It didn't work as easily in my opinion as plane old mineral oil. I've seen a few others but just figured they were similar snake oil.
Now before we get the usual array of "Well I use!!!!" comments I'd like to clarify. I've decades of experience sharpen knives and I probably sharpened more knives than most of you (certainly not all with respect to those with more experience) have in a lifetime before I was 15. Since I quit working for the family in my early 20s I've probably only averaged sharpened the same as the rest of you though. I know how to sharpen a knife, there is no one perfect angle or grind, and plane old mineral oil will work just fine. I'd like to know if anybody who has a lot of experience using mineral oil as a sharpening oil has found something that works definitively better as a sanding and polishing oil for modestly hard steel parts. (Typically RC28-RC32)
What got me thinking about this was that when I was picking out a selection of fine grit papers for final finishing before going to the buffer I noticed the packages said good for polishing steel when used with oil. I don't think I ever saw or maybe just never noticed that before. For sanding I always used water, and found that the coolant mix out of my milling machines works pretty well.
