U
umahunter
Forum Guest
Register Today
Well I have a shars magnetic base dial indicator that has failed after minimal use. I figured it would fail at some point cause of the plastic back just didn't think it would be this soon. its just a cheap plastic back that has a knurled brass screw pressed into the plastic. is there any reason I cant make a back piece out of aluminum and secure the brass screw to that anyone else done anything similar or have a better suggestion ???
