[4]
She cleaned up well for $25...
[3]
[10] Like what you see?
STurnerXM2010
Newbie
Feb 14, 2018
14
Ohio Forge ProSeries Model 510-505 horizontal bandsaw. I wish I had pictures of when I got it, but I had to rob this one off of a Google search. That being said, she was in far worse shape than the one referenced. Complete tear down with all bearings replaced. New blade and trued up the drive wheels. Cleaned and treated all hardware. Motor completely rebuilt and rewired (didn't need rewound). Retrofit a pneumatic linear actuator in place of the spring tension set up. I still need to dial that in as the arm and opposing vector require too much force for that little guy by himself (really don't want to go hydraulic, but may have to). Finally, 2 coats primer and 3 coats Rustoleum Professional High Performance Enamel. Black accents done by hand with black enamel. One thing I can say, this is number 5 of this style I've restored, and dialing these little ones in is a lost art. The bigger they are, the less of a challenge. These little 4"x6" dudes are like herding cats sometimes. Cuts like a dream and using it as we speak on a 4" I beam section destined for a benchtop bearing press.
STurnerXM2010
Newbie
Feb 14, 2018
14
Thanks! I was surprised at how stable she turned out to be. Usually these little ones rattle themselves across the shop before you're done. I replaced the sheet metal stand with 1 1/4" square tubing...that may have helped. LOL Here's the first cut as restored. Got a little accuracy back, for sure.
mikey
Dec 20, 2012
4,778
Nice, and it sure saves your arm. I love my Jet 5x6 and wouldn't want to be without it. Enjoy yours!
brino
Jan 2, 2014
3,486
Welcome to the Hobby-Machinist!
Nice job on the saw.
-brino
richz
Jan 19, 2012
149
Looks like it has a hydraulic cylinder for the down feed. Could you post some more pictures of that?
hman
H-M Platinum Supporter ($50)
Feb 17, 2013
1,945
Wowsers! You got a bargain, even as beat-up as you mention. And a fantastic restoration!
STurnerXM2010
Newbie
Feb 14, 2018
14
Unfortunately, it was missing the hydraulic down feed so I retrofitted it with a pneumatic cylinder and just use the bleed valves as the adjustment. Needed to add a little resistance to the cylinder, as it was not under active pressurization and did that by adding a combination of springs within the cylinder. There's just too much volume in this cylinder to have any effect until the last 10-15%. With the springs, it does well and all without the mess of the hydraulic set-up.
STurnerXM2010
Newbie
Feb 14, 2018
14
I apologize for the late response. Here is that pneumatic set up were we discussing.
DougD
Mar 29, 2015
55
Nice restoration and good deal!! Changing out the stand on these saws usually has a dramatic positive effect on thee cut quality.
Curious, you said you changed out some strings on the cylinder, did you add any oil in the cylinder. That is: modified hydraulic from the pneumatic cylinder?
[6]
[5] [7]
