eeler1, I have a 5400, as well, I would take the whole thing apart and clean, lube and check it. replace any small parts that need to be replaced. If it is older an you need to you can change out the backlash adjusting nuts, etc. Looks like you got most of the stuff to go with it, right off the bat. It looks like you have one of the older ones which do not have thesocket head screw en the end of the lead screw. So to take the hand wheels off is like the others said, look for the hole in the zero adjustment by loosening the small thumb screw on the wheel, then turning it till you see the set screw, take the alen and release. if the person has tightened the set screw to much, it may be hard to take off as it will have slightly damaged the end of the lead screw. But it will come off with a little work. I know from experience. I did not see a gage in the picture, But you will need to tram it so that the motor is square to the table. Good luck. I have used mine and am still learning but they will do nice work. Keep an eye on ebay for extras and parts. Some times cheaper than direct from the company, Also A2Z and others make aftermarket stuff and larger cross slides etc.
