Shop made insert tool holders
ChrisAttebery
Rocket Nerd
Jan 11, 2018
179
Disclosure: Like a lot of you I machine parts to pay for my hobby. If I wind up making these I will probably put them on my web store and eBay.
Every time I work on my lathe I wish I had a couple more tools available. The other day I was counting up the toolholders I'd need and realized that I could probably cut that number down by making up some double ended tool insert tools. You could use a turning tool in the normal orientation and a facing tool with the toolholder turned 90 degrees. I thought I'd start with a simple right hand turning and facing holder with zero lead angle. I might add a 3 degree relief angle to this. The tool is 5.5" long so there would be 1" overhang on each end of a BXA tool holder.
Next up will be a left hand turning tool but I'm not sure what to combine it with. Maybe an insert held at an angle so that you could chamfer with it?
MrWhoopee
H-M Supporter - Gold Member
Jan 20, 2018
1,650
I've been thinking about welding up a double ended SPG insert holder with inserts at 45 deg. for turning, facing and chamfering.
Janderso
Jeff Anderson
H-M Platinum Supporter
Mar 26, 2018
2,730
When you do, take some pics because I think it would be great to face and flip to chamfer. I always struggle with that one.
darkzero
Global Moderator
Staff member
H-M Lifetime Diamond Member
Nov 27, 2012
6,207
Look for the tools that Tom Lipton & Stefan Gotteswinter made/use. I use a similar tool but with SCMT/SCGT inserts. Can face & chamfer with the same tool, no need to change orientation. I just got me a second one last week. The same tool orientation is also available for use with SNMG inserts but I prefer using positive inserts.
darkzero
Global Moderator
Staff member
Nov 27, 2012
6,207
I find that the SPG inserts are out of favor
SPU/SPG inserts are still in production & can be found for cheap now since they have been around forever. Many milling tools that use them seem to be no longer made new though. My chamfering machine uses SPU inserts. I just bought a few packs of SPG inserts last week, name brand USA for $20 per 10.
MrWhoopee
Jan 20, 2018
1,650
Yes, I know they are still available. However, I just ordered 2 of the holder shown in my previous post and 10 SCMT09T308 inserts for less than $20.
petertha
Jan 15, 2016
829
Are you milling the pocket with the angled relief to match the insert bevel? That's what was stalling me for some shanks I wanted to make. I've since found some reasonably priced tapered end mills on Ebay or Ali. I think they are used in the mold making trade & come in different flavors.
ChrisAttebery
Rocket Nerd
Jan 11, 2018
179
I’ve put this on the back burner for right now. Were in the middle of repainting our house so I haven’t had a lot of free time lately. I did buy a 1/4” shank 4 flute carbide tapered end mill off eBay to do the edge of the pockets though. Hopefully I’ll get back to this project soon.
GunsOfNavarone
Jun 26, 2018
707
Do those of you that make your own tool holder harden them? What type of steel do you use?
ChrisAttebery
Rocket Nerd
Jan 11, 2018
179
Here's another tool I'm considering based on some of the suggestions in this thread. This is a double ended CCGT tool. The turning side has the insert at a 40 degree lead angle for turning and chamfering. The facing side has the insert at a 0 degree lead angle. It might be better if it had a -5 degree lead so it could be used to face and turn to a journal.
ChrisAttebery
Rocket Nerd
Jan 11, 2018
179
I'm not planning to harden mine. For the amount of use I'll get out of them I don't think it will be a problem. I might blue them to keep them from rusting. I've been debating using CRS or buying 12L14 or 1215. I'm open to input on the material choice.
darkzero
Global Moderator
Staff member
Nov 27, 2012
6,207
Chris, check out jazzd4golf on ebay. He sells a great variety of insert screws & tool holder hardware for excellent prices. All the screws I've purchased from him so far are great quality.
mattthemuppet2
Sep 28, 2013
2,170
Chris, most likely you're doing this because you want to (and who wouldn't? I have a couple on the list too) but standard CCxT holders can turn and face in the same set up. I have a couple of center CCxT holders (SCLMN?) for beveling which work really nice, but be aware that they're limited on the ID of tubes they can bevel as the heal of the tool hits the ID of the tube. I bought a small TCxT boring bar (looks a bit like a threading tool) to do those.
ChrisAttebery
Rocket Nerd
Jan 11, 2018
179
Thanks for the lead darkzero. I already ordered some from Carbide Depot, but I've saved his store on eBay for next time.
ChrisAttebery
Rocket Nerd
Jan 11, 2018
179
Yes, at this point I'm doing this because I can and not because I need to. I probably should just make myself a set of CCGT toolholders RH -5 degree, RH +5 degree, 40 degree, LH +5 degree, RH -5 degree. In reality there aren't a lot of combinations you can double up.
I'm not planning to use these for ID chamfering.
mattthemuppet2
Sep 28, 2013
2,170
being able to chamfer the OD and ID of a piece in the same op is pretty useful...
ChrisAttebery
Rocket Nerd
Jan 11, 2018
179
I ran a test piece last night from some scrap HRS. It looks pretty good, but I won't know for sure until I get the tapered end mill early next week.
mattthemuppet2
Sep 28, 2013
2,170
one trick is to layout the screw hole last. Mill the pocket as you see fit, put the insert in and lightly mark the center of the hole. Prick punch a couple of thou towards the outside of the pocket from the center mark. That will help pull the insert tightly against the sides of the pocket.
homebrewed
Jul 28, 2017
517
Comments on the tapered endmills got me wondering about my cheap set of insert holders so I took a look at them yesterday. The sidewalls ARE tapered but on one of them the taper doesn't go all the way to the bottom of the pocket, so the insert doesn't sit flat on the bottom. A true case of getting what you pay for.
I tried using one of my small files to clean it up but quickly discovered that the holders are hardened. I have a diamond file but unfortunately it has a square profile so I can't get to the bottom of the taper. I'll have to see if I can find something on ebay or Amazon that will work, like a small triangular diamond file.
Anyway, it often is educational (and useful) to me to follow these discussions. Thanks!
ChrisAttebery
Rocket Nerd
Jan 11, 2018
179
I've renamed this thread to "Shop made insert tool holders" because I think it more accurately describes where I am at this point.
ChrisAttebery
Rocket Nerd
Jan 11, 2018
179
I've wanted a better fly cutter for a while. I don't use mine often, mainly because it's pretty slow. I've thought about buying the Tormach SuperFly cutter a few times but IMHO the system and inserts are pretty overpriced. In another thread someone mentioned that they had a "Recycle cutter" that used the unused corners on CCGT inserts. I thought about making one for a couple days. I wished I hadn't gotten rid of the R8 shell mill holder that came with my old mill. Then it dawned on me. I can just make a version of the SuperFly tool to fit my Shars 2.5" R-8 fly cutter body.
darkzero
Global Moderator
Staff member
Nov 27, 2012
6,207
Probably me. I love that tool. I also have a FM45 that uses the same SEH_ inserts as the Superfly as well as a few fly cutters but I use the Recycle Cutter the most.
ChrisAttebery
Rocket Nerd
Jan 11, 2018
179
I don't cut much steel. I'd say 99% of my projects are in aluminum. I got the 1045 steel from McMaster on Monday. It is harder than the HRS I used for my test cuts but it has a beautiful finish when it's cut. I'm still waiting on the 7 degree mill from eBay. It was supposed to be here on Monday but the seller shipped it First Class Mail so there's no telling when it will actually arrive. I also ordered a liquid bluing kit from Amazon. I'm planning to blue these up when I get them done.
Birchwood Casey Perma Blue Liquid Gun Blue Finishing kit
mattthemuppet2
Sep 28, 2013
2,170
great minds think alike, I've been planning on making a flycutter to use those unused CCxT insert corners for several years, since I saw Darkzero's recycle cutter actually.
I'd suggest black oxide instead, it'll provide a more durable oil retaining coating than cold blue. 10g/l of ammonium nitrate, boil for 40min and you're good :)
Cadillac
Mar 12, 2018
1,442
From my experience the perma blue isn’t as good as I would have thought. I had bought this g96 gun blue awhile back which is a gel type and the finish was excellent. One coat gives a nice deep black oxide finish followed up with a light oil. Almost the same finish as what you’d get from a professional coating.
I recently bought the Casey perma blue just to see what else was out there. I have a gun I want to “blue” the hardware on and wasn’t impressed at all. I polished the pieces to be done, cleaned and coated. Found the coating wasn’t deep at all would wipe right off with paper towel and oil. Tried three coats and didn’t get any deeper or better results. Luckily was only 12 bucks but you live and learn. Highly recommend the g96 great product.
ChrisAttebery
Rocket Nerd
Jan 11, 2018
179
Thanks for the review Cadillac. I ordered a bottle to try out. I guess I'll return the Casey kit.
Cadillac
Mar 12, 2018
1,442
Here’s a picture to give visual of what I was saying about the products.
D901E7AF-D252-4E52-8147-1BF19F99C126.jpeg DB295B09-BF5D-4005-B5D5-AE8DCD698FE1.jpeg
The strap clamps were all done with the g96. No real prep other than degreasing and just one coat with g96 then a light oil. In the second pic the smaller piece was left over from something that was surface ground and had a mirror like finish. Thought it would have enhanced the finish. It got three coats of the Casey blue. Once each coat was applied they said to do a 0000 steel wool buff and keep applying to desired color. Well I steel wooled once and it took the finish off to the point it didn’t even look like I did anything. So I tried giving a coat let dry then rinsed and each time the finish would nearly all come off. The only thing I kind of liked was it was a more blue color than black but blotchy :confused:. My goal was to “blue” hardware which I am now looking into the old way with salts and heat. I’ll post pics when I get my desired look. Have a good one.
AdBlock Detected
I've Disabled AdBlock
