- Oct 13, 2012
- 175
I'm putting together some workholding clamps that I want to use on my CNC mill and CNC router. I'm modeling them after Bob Adams' clamps [1] . Instead of aluminum, I'm cutting them out of 1018 cold roll bar stock for the sides and 12L14 round for spacers and pivot. Bob's design used 8-32 bolts/nuts to hold the clamp together. I can do the same, and even bought additional 1/2 12L14 round to cut them out of. I'm considering alternative approach of simply using a 1/2" spacer drilled for 1/4" and either swaging a brass tube or using a brass pin as a rivet. I was curious if anyone had any alternative ideas?
If your curious how these clamps could be used on my CNC mill and CNC router, I was planning on making two sets of pivots. One drilled for clearance for 1/4-20 bolts for the router CNC router and the other for 3/8-16 bolts for the CNC mill.
-Freeman
[1] http://www.cad2gcode.com/cncprojects/id14.html
-Freeman
