- Mar 19, 2014
- 2,681
Several light years ago I made the pictured below 50 ton pneumatic/hydraulic press. At that time its intent was to drop Model T front ends, but nowadays I use the press to smash the bejesus out of projects that go astray. It does not have a jack handle to operate, just open the air pressure valve and away she goes. Maybe of interest is the quick adjust/feed on the ram with Buttress threads. And the hand crank winch used to assist in raising and lowering the table. I picked up the winch at a local Flea Market, I think it was a boat trailer winch in another life. I procured the tank, pneumatic amplifier and winch everything thing else was homebrewed.
- - - Updated - - -
Also along the topic of smashing things, is the below pictured 3 ton arbor press. But, now with a hole in the end of the rack/ram. I can’t believe how handy the recently acquired arbor press has been. And now that I have it, my bench vise has gotten a break. The arbor press is now a must have in my shop. And to make it even more useful, I put a hole in the end of the rack so attachments could easily be fitted. To make the hole, I attached the rack to a Bridgeport table on the back side. The rack is positioned vertical with the not business end of the rack pointing to the floor, and that end of the rack was shimmed off the floor for support. Swung the BP head around at the base. Lined things up and made the hole.
- - - Updated - - -
