Great points / Q's that I can address:
When I started working on this, I did some measuring of the fitting and the tap to give me a rough idea of how far the tap needed to run. Its not super precise, but it definitely helped give me an idea because I had wondered the same thing (how far in does the tap need to go?). But between measuring and 1 trial on scrap: it didn't take long to figure out.
My fittings install with 90% of its threads engaged (
similar depth if not slightly more than any commercially available part I've used). So I'm pretty sure I'm good to go there. Its quite snug. Although it doesn't require it, I do use a 2-3 wraps of teflon tape; helps with corrosion and galling if nothing else.
I am using straight drills; 7/16" drill for 1/4"NPT, R-letter drill for 1/8" NPT (
per the book). I do not have a taper taper drill or reamer. That does sound ideal, but don't have any on-hand. The straight hole does result in noticeable bit of increased resistance near the top of the tap, but it was manageable since I'm just tapping aluminum. I could see potentially up-sizing the drill in harder materials...or tapered hole if I had the means.
Anyway: the drill size was not my issue; it is the depth of hole required to get the necessary tap diameter dimension at the top of the hole. Using the stock tap, the bottom ~quarter of the threads created by the tap are never used / could never be used.
In other words: if I just used the first quarter of the tap: it would be impossible to even start installing a fitting.
I agree on using quality taps; I've broken enough crappy taps
to know that $ is well spend good brands. But for my NPT I only had a couple; one a crappy brand (Hanson/Irwin), and the other is an OSG (decent).
