- Jan 5, 2012
- 62
I do kinetic metal art work, and I am finding that I really need the ability to turn custom parts for one reason or another. I deal with gears and sprockets often, and would like to combine mismatched or odd types of these pieces together to actually function. In the short time I have started working with these sorts of things I have already had the desire to turn my own bushings, notch a shaft for a C-clip, bore out an ID in a gear/sprocket, turn down a shaft, put a keyway in a sprocket or gear, add a flat to a shaft, make a place into which I can press-fit a bearing or bushing, and on and on. I also would like to learn how to make my own gears at home. In addition, I would like to be able to create mounts to which I can affix all these pieces of machinery.
Now, with all this in mind, should I be looking for a lathe or a mill as my first home shop machine? My shop is in my basement, so headroom is a concern. It's also impossible to get something large down the stairs, though I suppose I could move things out to the garage if I found a piece of equipment that was worth finding more storage space for the Chevelle that's currently in it.
Any thoughts from those more experienced would be greatly appreciated. Also, if you know of some reading material or videos that might help me get a better idea of what I want, that would be great. I love doing research, and, though I'd love to have a machine in my shop in the next 24 hours, I hate to spend money on a whim, because regret seems to hang around forever after the money is gone. Of course, I don't have much money. As an example, I was looking at an Atlas 6" lathe on Craigs List for $650 as something that might be affordable for me. Would love a Bridgeport, but unless a miracle occurs, well, that's very likely not going to happen, and I'm okay with that.
I have been wanting to get into home machining for quite some time now, and I'm very happy to have found this community. I'd appreciate any help you all could send my way.
Tom
Tom
