Hi guys! New here and looking to upgrade my lathe. Found this one in the local classifieds. It's a Andes 13x40 made in 1991 in Taiwan. its pretty clean and comes with some tooling, DRO, and a 4 jaw chuck. When looking it over I noticed the compound slide didn't extend inwards far at all, and upon looking closer I saw that there was some metal deformation near the gibs, and it was obvious by the markings that it came from being crashed into the chuck. The guy selling it took a file to it knocked off the high spot and the compound moved freely to both limits. compound slide assembly is solid with minimal backlash. However, the cross slide has about one full wheel rotation of backlash, and the whole cross slide assembly can be moved forward/backwards about 1/8". The gibs are tight and there is no left/right movement. I don't know if that play is from being crashed, or from the large amount of backlash...?
I tried turning a small (about 5/8" diameter) steel rod. No noticable chatter. Put an indicator to the chuck backplate- less than 0.001" off, the chuck body itself had 0.0015 deviation while rotating by hand.
3 questions:
-what other test should I perform to see if it's been damaged from being crashed?
-Should I buy it?
-how much should I pay for it/ what is it worth?
3 questions:
-Should I buy it?
