There's a member here, jeff in pa, he makes some really cool parts for those. You might want to look him up and check out his stuff, he's a good guy and we have traded some stuff before.That's my buddy's last H1 set up as a cafe racer. It doesn't look like much but it runs pretty good.
Sent from my SPH-L710 using Tapatalk
Thanks for the tip woodticgreg I hadn't thought that the fix would be that simple. This makes sense as the problem didn't occur slowly. When I think back it started after I had been doing interupted cuts on square stock. THANKS AGAIN, BRIANtoolpost, on the back side of the saddle on the bottom are 3 bolts, snugging them a little may take out some of that deflection. Do not tighten them to much as the saddle will bind, just enough to take up the play.
When you did the one shot oiler, did you use a bijur system or one of the imports? do you hvae to worry about running the lines equally from the metering unit to the oil ports to eliminate any points from getting less oil than others? i have been wanting to add a one shot system to my VN 12, just havent looked into the logistics of it all yet.
Thanks
Todd
