- Dec 6, 2011
- 217
I bought a X2D mill from Little Machine Shop. I have used it for several projects. Started to side mill an aluminum bracket and everything was going well until the machine just stopped. It ran for about 10 minutes before the stall. I was only milling a profile thickness of 1/8”. No yellow light or other indication of a problem. If I turned the mill off and back on, it would run for a few seconds them stalls again. turn it off for and hour or two, it will run fine then stall again with no load.
Anyone seen this problem? LMS is closed due COVID 19 virus.
