- Dec 24, 2020
- 1,030
The type B overarm support for my K&T mill was missing a few bolts along with the sight glass parts when I got it and I'm starting to make/buy the parts to fix it, but can't figure out how the arrangement could possibly work as it sits. I bought a much nicer overarm type B support from Lost Creek Machinery and that one simply needs new glass (original was cracked) so I have something to compare to as I fix up the original.
They both have a piece of tubing that goes vertically from the oil reservoir down to the bronze bushing for the running bearing on the arbor. The thing that has me confused is that the tubes are pretty tall and line up pretty closely with the "high" mark. I can't imagine how they would supply oil if the reservoir isn't nearly full. In other words, when the oil is showing near the middle, much less at the "Low" mark, how could it supply oil?
Here's a pic of the original showing the tube and then a picture of the second support with the reference marks. I also have a type A support with the same setup, so I know they're all pretty much the same What am I missing? Is it the restriction caused by the two holes in the plate that separates the glass from the reservoir?
