Im not sure how much success you will have trying to silver braze a hss cutter. There are heat sinks and pastes but the cutter is so small I dont think you will be able to control the heat migration effectively. Carbide and silver braze play well together but hss not so much ... at least in my limited experience. I think you might have better results trying to micro tig weld the hss cutter to the substrate. Fabricating a cutter from annealed material and heat treating is another option that you have probably already considered. I think This Old Tony did a vid on this subject some time ago if you have not seen it it may be helpful. BTW I really like the cutter box you have come up with is that your design?Getting ready to silver solder a hss cutter to a base for rifler cutter box. I need a heat fence for the cutter area so it doesn't get hot....anyone with any ideas on a product
