Sine table
RobertHaas
Mar 16, 2016
132
Fairly straight forward.
2 1/2 solid round bar stock, turned it to true. Bored 1 1/2" into both ends for the lugs.
Built the Lugs
here is one of them
mounted it in the mill and cut a 1" deep slot in it.
Milled a flat piece of 3/4" steel plate and inserted it in the slot. Clamped it and welded to the bar. Once cooled I used my surface cutter and ran it down to height. so at zero degrees the table resting in a T slot on the mill table is exactly 2 high.
Drilled the field 1/2" on center grid using the grid feature on the DRO. 1/4x20
Flipped it upside down and bored it for my machinists jacks foot.
I use a Browne and Sharpe machinists jack I picked up on E-bay for 20 bucks
Nice, but how does this work? With a sine bar there are two cylindrical surfaces that no matter the angle are always a known distance apart from contact to contact. How do you get that effect?
I second that question. How do you accurately set the angle?
