Sine v tool makers vise
Dustin_Housel
Feb 8, 2016
22
If you had to choose right now which one and why!? I'm sure both are mandatory but the sine looks handy
Sent from my SM-N910V using Tapatalk
both will hold work just fine, the sine vise allows for angular milling- but some makes of sine vises, you can't lay on its side
the sine vise is generally taller than its toolmaker counterpart, this a consideration for smaller mills that don't have a lot of headspace
both will hold work just fine, the sine vise allows for angular milling- but some makes of sine vises, you can't lay its side
Excellent point about laying on its side. I know at some point I'll buy both. Thinking sine first as I've yet to find a use for a tool makers for the operations I'm doing. Everything I do is accomplished in the vise, angle block or the rotary table
The toolmakers vise is probably more rigid than the sine vise, but is less versatile. Part of this depends on size as well. Smaller toolmaker and sine vises can be fit in a larger vise, allowing angles, including compound angles, to be set during clamping the smaller vise in the larger one -- for smaller parts.
