sleeve puller
endmill
Sep 1, 2011
46
Need help figuring this out. I can make out National Machine and Tool, Jackson, Mich. Tried to find it on the internet, could find anything. What's missing? Thanks Dave
B
Bill Gruby
Forum Guest
Register Today
Go to you-tube and see sleeve pulling. There are quite a few there. You may find one that utilizes those cylinders. The ones I saw were all manual. It's a start, hope you find it.
"Billy G"
gheumann
Nov 4, 2011
121
Just guessing, having never used one, the only thing missing is a threaded rod that holds those squared off round plates. The way the hole is drilled in them, they can tilt at an angle to drop down through a cylinder with sleeve, then fall flat to engage the bottom of the sleeve. The cylinder is placed on the base, the bolt somehow suspended the from the cross bar, then jacked up. The cylinder would have to be held down somehow.
MikeM
Apr 14, 2013
12
That looks shop made. These are guys are spot on. There would be a rod between the puller and the adapter to pull the sleeve. Normally with a pivot at the adapter end.
That larger triangle shaped plate is used to install a sleeve. It would go across the bottom of the block. I suspect the other large plate is for the top when installing a sleeve.
AdBlock Detected
I've Disabled AdBlock
