[4]
Slitting saw question
[3]
[10] Like what you see?
jmarkwolf
Nov 9, 2012
328
Likes
195
#1
Regarding some thin aluminum angle thats 24in long and approx 0.055in thick. It's the cover for one of the scales on my DRO.
I need to trim one side down. If you picture some 2in x 2in angle aluminum, I need to trim it down to 2in x 7/8in, for instance.
I think the material is too thin to mill.
Is a slitting saw in my mill a good choice?
FLguy
H-M Supporter - Gold Member
Jan 11, 2016
256
Likes
140
#2
Got a table saw? Rip it and file the edge burr free and your finished.
chips&more
Mar 19, 2014
2,462
Likes
1,790
#3
Sorry, but using a table saw for that sounds like a VERY dangerous idea! Even with the blade just peeking above the cut. Sounds a lot safer if you did it on a band saw:). Please be safe...Dave
jmarkwolf
Nov 9, 2012
328
Likes
195
#4
No don't have a table saw.
I tried to do it with a Dremel router table and a fiber cut-off wheel, but I burned up the Dremel after about 6 inches. No loss, the Dremel was about 30 years old. :)
FLguy
Jan 11, 2016
256
Likes
140
#5
Done all the time in machine shops provided you use fine toothed carbide blade and a good wood "pusher".
Ken from ontario
H-M Supporter - Silver Member
Dec 26, 2016
960
Likes
700
#6
If you don't have a vertical bandsaw,then a thin cut off disc on an angle grinder will do a quick job of that ,you can machine it down to 7/8" on the mill later.
Bob Korves
H-M Platinum Supporter ($50)
Jul 2, 2014
6,057
Likes
6,386
#7
Hand powered hack saw, been doing it for at least a hundred years. Cut to rough length, file to finish size and pretty.
markba633csi
Apr 30, 2015
3,064
Likes
1,585
#8
+1 hacksaw and file
newbydave
Dec 25, 2012
36
Likes
7
#9
You should be to cut that thickness of aluminum with utility knife. Score or 3 times and snap off and lean up edge with file.
jmarkwolf
Nov 9, 2012
328
Likes
195
#11
Update:
Thanks for the suggestions everybody.
I was looking for an excuse to use a slitting saw for the first time, but it turns out neither of my R8 slitting saw arbors fit the spindle on my new mill properly. On one, the index pin slot is too shallow and it wont slide in at all, on the other, the slot is not long enough and it is apparently jamming the spindle index pin. Time to upgrade to a US made one.
So I'll just band saw my DRO scale cover and clean it up with a file.
doc55
New Member
Dec 7, 2014
27
Likes
42
#12
Yes with a carbide tipped blade no problem. We used to cut aluminum plate that way all the time we also used a router to do radius on part edges. With carbide you can use wood working tools and their higher RPM.
RJSakowski
Feb 1, 2015
3,681
Likes
4,286
#13
I've done a number of these covers. Rough it out with the band saw and finish in the mill. Mount the angle for a facing cut with the finished edge just above the vice jaws and use a 3/4 x 2" block to stiffen the edge. Cut with the end mill off center so the cutting forces are in the direction of the angle to minimize vibration. Cut about six inches at a time then reposition work and continue. You may have to do some blending at the intersections of the cuts, depending on how carefully you set up.
jmarkwolf
Nov 9, 2012
328
Likes
195
#14
OP here with an update.
I didn't want to wait until I could replace my cheesy slitting saw arbor, so I decided to proceed with the bandsaw, and clean it up by hand file.
Later today and/or tomorrow I'll get the X-axis scale installed. That cover won't require any trimming.
Pic below:
homebrewed
Active Member
Jul 28, 2017
189
Likes
88
#15
I think you can mill it, if you cut a slot rather than milling away 1-3/8" of material. Sort of like a slitting saw I suppose. But that way you can clamp most of the 2" side in your vise, and the horizontal side will be pretty rigid. It's just a soft aluminum extrusion after all so the cutting forces should be relatively low. If it was me I'd use something ~.1" thick as a spacer to elevate the top of the extrusion above the vise, then remove it after the angle stock is secured in the vise. Then go to it.
You likely will have to do it in sections (who has a 24" wide vise anyway???) but for a DRO scale cover you don't need a lot in the way of accuracy.
Machine shops wouldn't take this approach because it would take more time and not be perfectly uniform, but you don't have to do it their way. "Perfection is the enemy of good enough."
Mark
[6]
[5] [7]
