- Feb 12, 2014
- 53
Hi Guys and thank you for the nice regards on my Steam Engine. Attached is a few pictures of the boiler I built to run this engine. It is electrically heated with a heater for a residential water heater and a thermostat. The thermostat is set to generate enough heat for just under 60lbs of steam as the safety valve is set to relieve at 60lbs. The boiler is copper and silver soldered together with additional stay bolts. I made the die set to press out the end bells from aluminum plate rather than hammer forming them over a wooden fixture. The base was made big enough to be able to mount my original steam engine along side of the boiler, just never got around to it. Hope you like it as well.
Regards, Pat
Regards, Pat
