[4]
Smithy Extras I should buy
[3]
[10] Like what you see?
Boojie
Active Member
Feb 18, 2019
44
I have a CB-1220XL ( essentially a MI-1220XL). I was planning on ordering the Chicago bolt Smithy sells for mounting a QCTP. While I am paying the $11 handling fee is there anything else I should get from them? I know it’s a loaded question LOL.
markba633csi
Gold
Apr 30, 2015
3,447
Is this an item you can't make yourself? I'm guessing it's a chicken and egg problem?
mark
Boojie
Active Member
Feb 18, 2019
44
mark
For the $9 they want for the bolt it makes more sense to buy it than to spend my time on it.
I’m just wondering if there are some other things I should buy from Smithy ( that I can’t get elsewhere )
I have a steady rest and the standard Smithy accessory kit.
markba633csi
Gold
Apr 30, 2015
3,447
I hear that- I would say any items that are non-specific to Smithy you could most likely find them cheaper elsewhere, tool bits and so forth
You might want to buy a spare chuck backplate if those are unique to Smithy, in case you want to fit another chuck
Also high-wear items like half-nuts perhaps, depending on how much you plan on using power feed on the carriage when turning
TDPurcell
New Member
May 9, 2014
27
Threading dial if your machine doesn’t already have one. They’ll include the dimensions for making a bracket for it.
Boojie
Active Member
Feb 18, 2019
44
Are you referring to the dial that rotates as the feedscrew turns to let you know where to start making thread cuts again?
TDPurcell
New Member
May 9, 2014
27
Yes. I don’t think it’s a standard option on the older 1220 Midas machines (or at least the used one I purchased did not have one). Smithy has a threading dial that can be purchased separately (or they used to) and they will also send along a .pdf blueprint for making the bracket for it. I assume they still sell these.
[6]
[5] [7]
