So I want to make a keyway..
It does not take as long to cut a key way in aluminum in the lathe as you may think. It goes pretty fast. Don't overshoot. This could also be done on the BP.
Robert
Worst case is to use a multi-blade hacksaw to rough it in and then clean up with a small file. I didn't like it either when I had to do it. But, in aluminium, it isn't hard. The best bet is to acquire the broach. A shaper, if you want one. But it should be as a generic tool, not just cutting keyways.
It's all about time and money. The only advantage to using hacksaw blades and a file is it's available "right now!" and it's cheap. But otherwise, a PITA.
