soft jaws for your milling vise
what is your preferred material for soft jaws in your milling vise
  • aluminum
    Votes: 11 84.6%
  • brass
    Votes: 0 0.0%
  • copper
    Votes: 0 0.0%
  • bronze
    Votes: 0 0.0%
  • Mild Steel
    Votes: 1 7.7%
  • all of the above, ie. one of each
    Votes: 1 7.7%
  • Total voters
    13
tfleming
H-M Supporter - Gold Member
Nov 21, 2015
226
So, what's on your mill vise?
I use AL softjaws almost exclusively on my mills. Big fan of softjaws in the lathe also.
Good catch Bob, I should have included that in the survey. I am getting ready to make a couple of sets of soft jaws. Looking at the different prices of Brass vs. Copper vs. Aluminum vs. bronze, I see why everyone is using Aluminum. Mild steel is also an option. Right now, I am leaning towards brass, but that might change. In any case, I think a set of mild steel jaws is in the making as well.
Let me help, all done. :encourage:
To be clear, I have never made soft jaws of any material for holding special shapes of work. I make and use mild steel standard every day jaws because they are cheap, easy to make, hard enough to hold work without significant wear in my home shop, and easy to dress if slightly damaged, even in place. They are also easier on your cutters if you accidentally run them into the jaws, not that I have ever done that (so far!).
