Hi @ycroosh and all,
I'm eagerly awaiting my DRO parts, and I have a question about extensibility of the TouchDRO app.
Does TouchDRO support any kind of real-time import-export of data?
As a customer and excessively creative engineer, I want to use the TouchDRO user interface with any data source available in software. For example, I may have a machine tool with integrated, networked sensors, but not the user interface I need. I love the TouchDRO UI, and the data is available just not via Bluetooth/USB. I need a way to get it into TouchDRO.
In a separate but related situation, I have a machine tool with TouchDRO hardware and software, and I want to use the data in ways that are out of scope for a DRO. For example, I want to use TouchDRO as feedback for a CNC system. Or I want to monitor spindle speed, thermal and electrical conditions together. It needs to be real time, not a file export after the fact.
I'm hoping for a local socket or other IPC interface.
I like that approach because it can be super decoupled, such that TouchDRO knows nothing about the source or destination.
I think it would be great.
Your thoughts?
- It doesn't require any configuration, or at least not more than any other input. It just reads data if it's there, and writes it into the void if no one is listening.
- The built-in Android access control is sufficient for security: if you can access a local socket, you're already good.
- Data formats can be the same as the Bluetooth adapter and file export feature.
Your thoughts?
