Some work on a TX650.
I've done it, but went ahead and spun and threaded a new plug on the lathe. Discovered I was doing a pretty good job of setting the floats static.
I set my floats at 24mm as per the specs. At this height the fuel level is supposed to be 2mm below the level of the upper carb body. When I measured the fuel level, it was 3.5mm. So, setting the float level won't necessarily give you the right fuel level.
Synced the carbs and checked the PMA today. Bike runs beautifully now, idles nicely, revs cleanly, no spitting or hesitation. PMA/reg/rect output is 14.6 volts, so happy with that as well. Timing is spot on on both cylinders, so the single points cam also works well and the filter and cooler deliver a good oil supply with no leaks. Fancy that, all the engine mods worked as planned! This is my homemade manometer I use for syncing, super easy to use, gives a good, stable reading.
I nutted out a simplified schematic for the TX last night and did a little work on it today. Rather than one harness, I decided on two, one for lights and one for ignition and charging. Five wires for the lights run up the left side of the backbone for lights, another three run up a harness on the right for ignition. I've included some earth cabling in the harness rather than just depending on earthing through the frame.
Once I've routed all the cables to their destinations, I'll zip tie them then wrap the harness removing the zips as I go. Having one harness for ignition and charging circuits and another for lighting simplifies fault faulting and cuts down on the number of colours needed in the harnesses.
I've ordered some stainless spokes, should be here this week. Can only get front spokes at the moment for some reason, seems to be a shortage on rears. As soon as they arrive I'll repolish the hub and rims and spoke it up.
You don't hear a lot of people lacing their own spoke now days. :encourage:
"Neat and workman-like" was an old Navy standard that applies here.
Speedo/tacho/voltmeter bracket made up today. I'll be adding a few LEDs later on for oil, indicators and so on.
Started the TX up again to check the tacho and voltmeter. I had intentions of checking the timing on each cylinder, unfortunately, the POS timing light refused to play. Not to worry, max voltage from the PMA was 14.5 and the bike idles nicely at around 1250 RPM. I placed the camera behind the bike to record the exhaust. Camera doesn't do it justice though, it's very loud and emits a nice burble.
Nice, I had a Honda 305 that sounded similar :)
Front spokes arrived this afternoon, so I laced up the wheel. The spokes for the rear wheel are coming from Heiden Tuning, so they probably won't be here for a while. Much better looking than the mags I think.
