Thanks for all the help! After looking at the links you all have provided, the rubber bits I need are not standard parts. BUT I have been able to piece some parts together that should work from orphan OEM seals from eBay and sheet gasket material. Next step is to find a replacement "gegenmutter", part No.112. If I measured it correctly, an off the shelf camera lens adapter could work, One is on it's way from the Far East.
