Specially ground tool?
Jubil
H-M Platinum Supporter
Apr 13, 2016
336
Does this boring bar use a common shaped cutter or a specially ground one? And how to shape/grind the cutter? The angle of the tool holder part seems odd to me. Many thanks for any help.
Chuck291983291982
That's probably for a round cutter. I have used broken center drills as boring tools.
Thanks, I have a round cutter, I will give it a try.
Chuck
That is an Everede boring bar, I have a couple. They take a triangular cross section insert that can be HSS or carbide.
See: http://everede.net/everede_2014_catalog_prod_style_bars_inserts.html
Travers sells the inserts (at bottom of this search):
Thanks, that answers the question for sure. I've had this for several years but couldn't figure out the tool geometry. It's very Stout and almost too big for !y 14x40 lathe
Thanks again
Chuck
