Speedometer Face-Lift for '63 VW Double-cab
Correct, there is a (dim 2w.) bulb on either side. I'm thinking about opening it up again :( and painting the inside white to get better reflection.
Or see if they have an LED angel eye big enough to go inside the bezel. Probably need a dimmer on it or it could play havoc with your night vision. You’d see the Speedo great not the road.
I wish you hadn't mentioned that, now you have me thinking....
Yea, it would probably be too bright....
Two whole retina burning watts!
That looks great!
really impressive work! I wouldn't be able to tell that from a stock piece. I wonder if there's a market in knocking a few more out?
Possibly. The face plates would have to be cut by laser or water-jet. The question is could I sell enough to cover the minimum order.
I've grown tired of not being able to see the speedometer at night and the visual mismatch with my other gauges. After determining that there are no commercially available replacements and I couldn't afford to have someone else do it, I decided to do it myself.
Here's what I'm starting with:
Here's what I'm trying to duplicate
First I did the graphics in autoCAD, printed on adhesive backed vinyl label stock. I made punches to cut the center hole and mounting screw holes
When I disassembled the speedo, it dawned on me that the face is not flat, and the vinyl face overlay would not go on without wrinkling.
So I decided to make a flat replacement face.
and the finished product.
I decided to let the warning and turn-signal indicators shine through the vinyl instead of cutting openings, leaving a cleaner face.
I've ordered LEDs, hope they're bright enough.
How in the hell did you do that?
It’s beautifully done.!
Thanks, it turned out almost as good as the picture in my mind.
Which part of the process are you asking about?
