- Jun 20, 2022
- 200
40 year old RF mill drill clone. New to me. First cuts have half moon artifacts. Everything else seems tight so I checked the spindle with an indicator.
I'm getting no play on the quill, but when the spindle is checked I get .001" play in the spindle. Being a newb mill owner IDK if that is considered normal, or excessive.
The Enco manual refers to bearing preload adjustment. I see these collars are here for that purpose. Should I try that? Or is it simple more likely the bearings are worn and this will go no where without new quality spindle bearings?
Thanks!
ETA: I'm using an old end mill from a friend's grandfather who was a machinist 50 years ago.....possible its the cutter. I do have new ones on the way.
Thanks!
