Stainless fasteners seizing up
shares
Well I learned something new today by simply spell checking my subject, ha ha!
As the subject suggests, I've had a couple occasions of inexplicable seizing up when using sstl fasteners. It happened again yesterday!
Apparently I'm supposed to lube or sstl can seize up like that - Wholly crap I've had 2 or 3 sstl fastener seize-ups in the last few months...
Not a nube, I promise!
Stainless in stainless? Yes, galling is a definite possibility, particularly with fine threads or tight class fits.
Burns my butt! I had to take the angle grinder to a 3/8 SSTL Soc hd cap screw seized up in a stupid little T-nut! Argh!
It seems the larger the fastener the bigger the propensity!
I worked for over 20 years for a major food manufacturing company that built 90% of their processing and packaging machines inhouse. Any fasteners used in or near a food contact zone, or in a heavy washdown area required stainless fasteners. For many years the specifications were mandated from the USDA headquarters in Washington DC. The material of choice they specified 316 stainless. Once a set of prints was approved at the national level it applied all of that type of machinery across the country.
In the 1990's that responsibility was passed down to the local inspector plant level making things much more difficult. Each inspector could mandate whatever fastener, fit, finish or any other specification they thought best for the application in the plants they inspected. That meant rather than making 1 standard machine we could possibly be required to make 45 different versions depending on the USDA inspector in charge.
Standard Permatex Anti-Seize was used in nonfood contact areas and food grade Anti-Seize was used in food contact areas. However, even the term "food contact area" got blurred over the years. Some inspectors considered the area to be within 1 foot of the actual product while others considered it to be up to 3 feet.
The standard anti-seize always worked far better than the food grade. Unfortunately, it was messy by comparison, so the machine had the be fully sanitized after removing or replacing any fasteners that required its use.
The use of anti-seize became so ingrained I use it on almost everything (that doesn't need Loctite) that will be exposed to weather or washdown. So far, it's been well worth the effort. Sometimes it's messy, but 5 years later when it comes to disassembling it makes things much easier.
Also of note is "most" big box store stainless can be "of lesser quality" and/or lower standards.
So you need to be careful and consider the loading(s) on the fastener(s). I've seen folks in the car clubs replacing fasteners with St.Stl. to "add flash" and the fasteners they are buying at home depot and the like are completely wrong for the application. Not trying to preach, just something to keep in mind I guess.
anti seize. But now Ed's post tells me my Anti Seize may be a problem. I guess I should get a copper based as well.
