Steel Stamp Guide
Larry$
Dec 21, 2018
1,786
I made this from mostly scrap. 1.5" Aluminum angle, Salvaged aluminum blocks, aluminum disc from metal poured into a can, 3/8" all thread. The movable block was slotted 1/8"+ with a slitting saw. It is used by clamping it over the target metal, holding a steel letter stamp against the moveable aluminum block, tap to imprint metal, advance the guide while aligning the double indicator lines to the center of the next letter. The idea was that I could use computer kerning and get nice straight lines of letters or numbers. Might have worked but the letters are not centered on my cheap set of stamps. The hand wheel advances the alignment block 1/16 / rev. The 1/4" Lexan has blSteel Stamp Guide B.JPGack scribe lines top & bottom to eliminate parallax.
Nice idea, sounds like you may just need a better set of stamps.
I’ve had sets of these for years now and really like them. Nicely finished, good letter formation, and even imprint. Prior to these I had one set that I bought from Acklands that were absolute garbage.
