[4]
[Metrology] Stocking up the home shop?
[3]
[10] Like what you see?
S
SCLead
Guest - Please Register!
Hey folks,
Looking for a little advice from those who have set up their home shops in the past.
Long version: I bought my first house in the last year. More accurately, I bought myself a 30x30 shop, and there happened to be a pretty decent house standing out front. I'm not exactly starting from scratch, though I'm now able to organize much better, and add some more substantial tools (i.e. machines) to the mix. I started machining in college about eight years ago, and have been behind mills and lathes at pretty much every job since that point, though I'm far from being a machinist. Thanks to this, I've gradually collected most of the basic individual stuff - 0-1" mic, 6" calipers, a good machinist square, small hole gages, etc. Far from "all inclusive," but I've been collecting stuff as I find deals too good to pass up, or as I need them to complete a job. Now, since I've got a lathe and am on the short list to picking up a mill, I'm looking for the bigger "shop items," which would normally be provided by the employer/shop, as opposed to "individual items" one might keep in their personal toolbox in the shop. I'm curious what everyone finds (trying to keep this on the "metrology" topic) getting a lot of mileage in your home shops? Things that fit this category that are already on my list are things like a good medium-to-large surface plate and height gage (I'm pretty sure I've worn holes in our Rahn plate at work, I use it so much), some larger angle plates and V-blocks, etc. I'm kind of all over the map in the "type" of work I do in the home shop - gunsmithing, automotive stuff to include boring/honing bearing races and the like, random "custom fab" stuff like bumpers, spare tire carriers, etc., and I'm recently taking a keen interest in "tightening up" my work - striving for tenths accuracies on things instead of thousandths. Tool & die work very much interests me, but I've missed that boat professionally, so I expect I might dabble finer and finer in the home shop - unsupervised and unafraid. Obviously a lot of this is "as needed" type things - no point buying tiny pin gages if I never work with small holes, so I'm just kind of curious what I might be overlooking.
Short version: What metrology tools do you find yourself using constantly?
Eddyde
Bronze
Oct 13, 2014
1,433
6" digital calipers are my go to for general measuring and the mic for those more precise needs. I use a height gauge and surface plate for most layout work. The DRO on the mill has become indispensable, though I have yet to add one to the lathe, mainly due to an impending lathe upgrade. Dial and test indicators are also indispensable for alignment tasks. Hole gauges and adjustable parallels are also frequently used.
S
SCLead
Sounds pretty on track with what I've already squirrelled away haha, with the exception of the height gauge and surface plate, which are near the top of the list for shop purchases (though honestly shop purchases are nowhere near the top of the overall list). Though no DROs here. Too stubborn to wedge them on to old American iron.
macardoso
H-M Supporter - Silver Member
Mar 26, 2018
297
My favorite tool is my Mitutoyo Digimatic calipers. They are your standard run of the mill electronic calipers, but have a nice fit and finish, and have outlasted several other pairs with no end in sight.
In the sad event that those die, I have a no-name mechanical dial caliper which never seems to be short on batteries :p.
Second most used is my Mitutoyo absolute micrometer. This was a gradutation gift from my dad.
For tool presetting (CNC) and general measurement, I use this shars brand 8" height gauge. Unfortunately my only granite surface plate right now is a 6x8" one from Tormach designed for tool presetting. Hope to pick up an 18x24" at some point.
For more precision work, I have a 0-6" micrometer set. Most of these are mismatched but I do have a set of standards with calibration certificates. I use these standards to qualify most of my tools.
My favorite indicator is my Fowler X-Test Swiss Type. It lost a tip to a keyway a year ago and I finally located the correct replacement tip. Glad to have it back.
During that year, I picked up a Shars .0005" indicator for something like $30. It works like a charm, but I do miss the swivel stem and double range of the Swiss indicator (Shars sells one of those too). I recently picked up a Noga style base from... you guessed it... Shars.
For measuring bores, I use a Mitutoyo 155-903 set of telescoping bore gages. These are a must have. For smaller bores I recommend either split tip style bore gauges or gauge pins.
For measuring depths of internal features or some external features, I have a Starret 0-6" depth micrometer. If you've ever tried to use the back of your calipers to measure depths and found it very frustrating, you need a set of these.
Less often used but very accurate is a Federal .0001" dial indicator. It is old, but runs very true. Really only used for tramming or measuring runout.
New for the lathe are a set of thread measuring wires, metric and imperial theard gauges, and a master precision level.
(honestly this is so sensitive you'll want to pull your hair out)
Finally one last pin micrometer, it is pretty beat up but I trust it for +/- .001" and has saved me on some small and difficult to reach parts.
I didn't take pictures of the various setup and layout blocks that I use, but having a number of decent quality 1-2-3 blocks, v blocks, and angle plates is a must. I also have a high precision cylindrical square for tramming my mill. I'm sure I forgot others but these are the main ones.
Not shown are a few sticks of a very tough green wax we used in the lab. Not sure what the material is, but we used it for checking inaccessible internal features. Heat it up, stick it on, let it cool then measure.
It is a never ending collection, but the more ways you can measure your part and machine, the more confident you can be as a machinist.
-Mike
Bob Korves
H-M Platinum Supporter ($50)
Jul 2, 2014
6,184
My surface plate is 18x24" and does about all I need it to do. But my shop is smaller, 730 sq. ft. 3 car garage that still fits one car. Large surface plates can often cost less to purchase than smaller ones. I have seen some really large ones given away. IMO, any surface plate that you have not personally kept track of since its last calibration should be re-calibrated before any serious use. An unknown is just that. However, moving and calibrating larger surface plates is a much bigger job, and the calibration can cost a lot more.
benmychree
John York
Jun 7, 2013
2,865
I wonder that we may take the issue of calibration a bit too seriously; sure, I take care to occasionally zero out my mikes against the standards that came with them all those years ago (about 50 or so), but do we need to fret over the flatness of a surface plate that we do layout on with a height gage that is graduated in whole thousandths and never has been calibrated and that the marks it makes on workpieces are machined to by eye?
It is one thing to need high accuracy of a surface plate that may be used as a scraping reference surface, and quite another for one used in day to day layout tasks. I have never felt the need for pin gages, and seldom even use drill blanks; perfect sizing of parts that we machine is seldom necessary, FIT is what IS necessary.
macardoso
Mar 26, 2018
297
Completely depends on the work you do. If you are making assemblies in the home shop then yes fit is absolutely the most important. If you have a customer print with tight tolerances and no way to check what it fits up to, then you need to measure tight tolerances and know your instruments will read the same numbers as everyone else's. That's where calibration comes in. Also depending on the industry, customers may require calibration certificates
benmychree
John York
Jun 7, 2013
2,865
Perhaps the name of this forum (Hobby Machinist) suggests that for the most part, we are talking hobby shops and hobbyists, not high tech workers and ultra precision venues.
macardoso
Mar 26, 2018
297
Fair point. I myself only dabble in projects that require accuracy in the realm of tenths, however there are plenty of hobbyists out there who consistently produce very high precision work. Your metrology needs are completely dependent on the kind of work you are doing.
benmychree
John York
Jun 7, 2013
2,865
I also deal with tenths, but not in the lower numbers of tenths ------- which can be quite problematic to measure, at best.
S
SCLead
I've got a Mitutoyo digital "coolant-proof" blah blah set of calipers. I honestly don't even remember what they look like, as I find myself reaching for my Starrett dial calipers. I have no reason for this, I wouldn't even call it a "preference," just how it is...because..? hah
I think I drooled a little at this mic. I've got some Starretts (all used/cheap ebay finds) that run so tight you can't even use the thimble to close it on open space, and I splurged on a B&S .0001, but boy...That's something else.
I do need to pick up telescoping gauges for sure, but they slip my mind. I have a...1-2(?) inside mic, and split ball type small hole gauges, but there are major gaps between the coverage of these.
I'm prowling for thread wires for a decent deal. I don't often find myself dabbling in metric threads (though as I write this, I'm realizing I own a BMW, Toyota, and a VW :eek:) so I haven't bought in to metric thread stuff yet. I've got a standard machinist level good to .005 in 12" - how often do you find yourself actually using the master level? I debate the need for one, but honestly don't know. Should I be watching for a deal so I don't miss it?
This is somewhere I'm 100% lacking. I have no v-blocks, no angle plates, and my only 123 blocks are "almost" 123 blocks I was progressing on in class years ago, when someone forgot to turn on power to the magnetic chuck on the surface grinder. They detonated a wheel, smashed the daylights out of the chuck, and destroyed a couple relatively minor parts of the machine, taking it out of commission before I got past 123.001 - 123.003 blocks or so. At least they're square and parallel.
I agree, and it's something that's been keeping me from pouncing on any surface blocks I see pop up for sale. I've only casually glanced, but I have no idea even what ballpark I should expect to pay to inspect and/or lap a plate of any given size.
I agree, to an extent. As has been mentioned already - totally depends what you're doing. I can honestly say I've never laid anything out and machined to the layout marks by eye, outside of school. You make an extremely valid point about fit being the critical factor, not the numbers, but that's also pretty limiting in terms of interchangeability. My perspective on the topic is twofold: one; I can always relax my standards, if I'm capable of holding them tight - if fit is all that matters, I can match machine something pretty easily. If my tooling is only good enough to match machine though, I'm going to struggle when I try to bore a bearing race in a transfer case housing or chamber a rifle barrel. Two; I'm a "train how you fight" advocate, and I do enough machine work to +/- 0.0005" during my day job that I feel like I'd just be inviting trouble if I came home to a "this is good enough" attitude in my own shop.
There's also the fact that I'm the type of person who needs things "just so," and I'd crumble if I knew my personal shop wasn't up to snuff.
A fair share of the work on my personal projects list calls for tenths accuracies, hence looking for advice on metrology equipment.
I'm also of the opinion that most people wildly exaggerate the complexities of high-precision measurements. It's just like talking politics - people pick one side of the fence and they cherry pick facts and stories to make their point. Sure, measuring to tenths and beyond is very dependent on outside factors, but as benmychree said, fit is what's important. Measuring in tenths for axial runout or parallel alignment could not care less about the ambient temperature, but your final product may very well care if you "only" measured in full thousandths. But I digress.
Keep the tips coming! I appreciate everything so far!
[6]
[5] [7]
