[4]
Storing Mill Accessories/Tooling
[3]
[10] Like what you see?
wcunning
H-M Supporter - Gold Member
Apr 21, 2016
117
Hey guys,
I'm in the process of policing up the shop to have a couple of walkways anywhere and a bit of flat surface... I'm sure you all know that feeling. :D
In that process, I'm planning on replacing a Craftsman tool cabinet with a cart with shelves to get some space to keep the mill accessories. Currently, I have a couple of R8 racks in the top of the Craftsman full of collets and end mill holders and boring heads and drill chucks, but I can't close the lid and they're pretty tight. I also have a pile of hold down pieces that don't really fit well in the tool box. All of that will sit on top of the cart, while the shelves inside will get my rotary table, dividing head, super spacer, spare mill vise, angle vise and such. I've attached a picture of the particular cart I'm looking at getting below. Do you guys think that a cart like that should be able to hold ~500 lbs per shelf?
In addition to the swap, I've also arranged to look at a Wesco die lift cart on Craigslist near-ish to me. I figure that it would be a good idea to be able to swap things on and off the mill without breaking my back... I should be able to set the die lift platform at the level of a shelf, pull the accessory out onto it, pick it up to table height, push onto the table. Does that seem reasonable? Does anyone have experience with these lift platform/cart things? Video below as well.
Thanks,
Will
T Bredehoft
Dec 27, 2014
2,833
Jump on that Die Cart. The shop I grew up in had a couple, the one I spent 21 years in didn't and boy did I miss them.
wcunning
Apr 21, 2016
117
I am jumping on it. I'll tell you guys where it was and what it cost once I have it in my truck. It's... a very very good deal even if I have to rebuild the thing entirely. :D
Ken from ontario
H-M Supporter - Silver Member
Dec 26, 2016
971
You can't go wrong buying that two wheeler for your shop,I used to use a more heavy duty battery operated type that could carry much heavier loads but if the battery was dead for any reason it would have made the lift a useless tool, the one with a foot pedal is perfect in every way for a small shop.
benmychree
John York
Jun 7, 2013
2,865
For my mill tooling I have a couple of large size card file cabinets and a regular filing cabinet with a wood drop in holder with holes for spindle tooling; my Fray vertical mill and my #2 B&S share the same 30 and 40 taper tooling, the dividing head sits on the top of a shelf unit and is handled by a electric hoist running on a "barn door" track above, the shelves below hold lighter accessories.
nnam
New Member
Jul 15, 2016
24
I had to give away a 400 lbs personal lift. It's great for lifting small things and easy to move around. Unfortunately, I had to make rooms for others. It looks like an engine lift, just much lighter and easy to pick up by hand and carry around.
wcunning
Apr 21, 2016
117
Thanks for the replies guys!
I just got home from picking up the lift -- pictured below. It looks like I'll need to pull the cylinder apart and replace the seals, but that's hardly something to complain about for $30, even with the 2 hour drive in each direction. It also needs to probably be cut back down to original size for my use, along with a replacement for the ruined front casters. This was clearly a four wheel cart originally and will be again by the time I finish with it.
Tim9
H-M Platinum Supporter ($50)
Oct 11, 2015
197
I think your cart is very similar to mine. I bought it from a scrapper for 30.00. Spent a few days freeing up the rusted chain and rebuilt the hydraulic pump. Also had to change a couple of the cam follower type bearings for the mast. But it's been working for about 4 years now. I have mine mounted stationary sort of like an elevator or platform lift so that I can lift heavy items to the 3' height of my front porch. It beats trying to get something heavy up a number of steps using a hand truck.
wcunning
Apr 21, 2016
117
@Tim9 All of my cam follower bearings are frozen... I kroil'd up the chain, and it seems fine, but the bearings didn't seem to want to break loose. I gave them about 4 hours in vinegar to eat into the internal rust, then I washed them out and put them in a jar of kroil slightly thinned with acetone. If they don't break free and roll alright in a few days, I expect I'll have to replace them. Unfortunately, looking up those bearings, they're pretty expensive to buy 4 of. It looks like I can save a little on eBay, particularly if I can find someone to combine shipping, but I'm sort of inclined to get some 62 series bearings for *way cheaper* and just replace them with something different. Is there any reason why I shouldn't do that?
Thanks,
Will
nnam
New Member
Jul 15, 2016
24
Great deal. $30 can only buy the two wheels usually.
Tim9
Oct 11, 2015
197
Those cam bearings are expensive. I found 2 NOS ON eBay so just changed the two upper mast bearings. I was able to free up one of the lowers and lube it pretty good. That was a few years ago and I’ve left it with one bad and frozen bearing. It’s been useable. I just relube every thing every so often. It has been a handy find.
wcunning
Apr 21, 2016
117
@Tim9 It looks like NOS brings the price down to $60 in just those bearings...
Looking the thing over a little more carefully, I think I need to do the following:
  • Replace the follower/cam/yoke bearings
  • Cut down the extended lift platform that someone welded onto this thing
  • Cut down/weld back to original shape the base that someone extended to support the extended platform (Can I get you to take some pictures of this for me, Tim? I'm not 100% sure what it's supposed to look like.)
  • Replace the front casters, which are totally ruined
After all of that, I should be able to avoid picking anything heavy all the way up onto the mill. I might also set it up to slide a chuck onto the way protecting board I have for the lathe, so that I'm never really lifting those either.
Tim9
Oct 11, 2015
197
If I had my lathe and mill up and running plus had the tooling then.... that I have now, I would probably just make my own.
They are overpriced bearings IMO. I’m guessing most of these bearings get used on forklifts which have much, much higher lifting capacity than these 700# capacity lifts. So yeah.... I’d just make a couple shafts with similar OD bearings on 3/8” studs.
wcunning
Apr 21, 2016
117
I had a thoroughly successful day yesterday getting all four of those mast cam bearings to free up. I let them soak for about 4 hours in vinegar to loosen the rust, then I gave them a couple days in Kroil thinned with acetone, and I finally clamped them with the appropriate bolt + washers + nut and used a strap wrench to get them to start spinning. They're now back soaking in the Kroil jar to hopefully do a bit more rust dissolving.
The big question from here is how should I lubricate them? What would I do to pack them full of decent grease?
Thanks,
Will
Tim9
Oct 11, 2015
197
I think if you lube them real good with some way-oil, you'll be just fine. Just lube them once a year. No need over-thinking this since it won't be stored out in the weather and won't be used 24/7.
wcunning
Apr 21, 2016
117
It's been out in the weather for a week or so since I fixed those bearings, and it's making a trip up to a friend of mine's shop. He's going to help me shorten the foot and weld it back together and cut the plate down some. Once that's done, I'll put the fancy new casters I bought for it on and it'll make it down into my shop. I'm deeply excited to try it out for moving heavy things around.
I'll post photos of the modification process after it's done.
Thanks,
Will
wcunning
Apr 21, 2016
117
Just a wrap up post on here, but I ended up not really being able to use the cabinet. It started bowing enough that the doors didn't line up anymore after about 500 lbs on the internal shelf (dividing head, tail stock, super spacer, several drill press vises). After staring at it for a *while*, I ended up getting some extra heavy duty garage shelving from Home Depot. It's pretty damn solid, and I've got at least 4000 lbs on it at the moment, as you can see in the pictures below. I did have to shuffle the mill over 9" to get the shelving to fit, so that was quite a bit of driving to borrow machinery movers from a friend of mine, also pictured below.
The lift cart doesn't get me all the way to the top shelf, but it does get up to the third one. This means that I won't be picking up anything over 100 lbs to load it onto the mill for quite a while. I'm getting my brother to build me a few chuck boards to go with my lathe chucks so that they 1) don't roll off of the shelving and 2) can simply be slid off of the cart onto the ways and then pulled up onto the spindle by the drawnut, meaning that I don't do any lifting on them either. I won't manage to avoid *all* heavy lifting, nor do I really want to, but I should have it minimized to the point that I'm unlikely to accidentally do something bad to my back. Here's to being able to still enjoy the hobby in 50 years!
[6]
[5] [7]
