- May 13, 2019
- 1,016
I'm converting my PM25 mill to CNC. I understand that climb cutting is the norm with CNC. Is this true?
Nope. Conventional milling all the time: (free of work) step X, move Y into the work, then Y back through & past the work, once past the work step X etc. That's why I thought I was being safe; but that first encounter on Y after stepping X was a doozie.Just checking, you were conventional milling in one direction, then move the end mill over and climb mill back in the other direction?
This is a story about something I encountered during a milling job on my Sieg SX2 mill.
The issue of climb milling can be tricky. I once encountered something I call "deferred climb milling" while milling a slot in a steel plate. I had the plate installed so the depth of the slot was in the Z axis, so Z was fixed and I was moving X and Y. So the side of the end mill was doing the cutting. The procedure was: after finishing one pass on Y, move Y back so the next pass would be a conventional milling operation. Step X over by the DOC my mill/EM could handle, then do another pass. Here's the deal. If I had moved X while the end mill was in contact with the work, that would have been a climb milling step, so there was some backlash in X waiting to be yanked forward by the cutting forces. So when I brought the end mill into the work to start the next cut, the backlash IN X came into action, increasing the DOC enough that the end mill grabbed the work and stalled the motor in an instant. Fast enough that it unscrewed the collet nut holding the end mill!! What did I do wrong? I failed to lock the X axis. I'm fortunate the end mill didn't break, or throw the work across the room.
Since that time I have tweaked/modified my mill to reduce the backlash in X and Y, enough to permit light climb milling in steel -- but I still make sure to lock all the undriven axes when I'm milling, Mill. Unlock. Step. Lock. Repeat....
It might seem like a no-brainer then to put ball screws on your manual machine, but their friction is so low that they can move under the machining forces -- they won't hold their position. And if you're climb milling that isn't a good thing -- the table could self-feed, despite your hand on the crank. Sounds bad to me.....
Was your Y-axis locked?I just read this thread with interest since I had something similar happen to me this weekend. I apologize if I'm hijacking but it's related.
On my new 833TV I was running a 12" long climb cut along X under power with a 1/2" three flute roughing mill (in an end mill holder) on 1/2" thick aluminum. When the table reached midway it started jump;ing. That's the only way I can describe it. You could see the table jump and hear the cutting difference. I was making about 10 passes removing about 1" of material in total (since it wouldn't fit in my chop saw) in .1" increments and this happened on nearly every climb cut pass but not on the return conventional cut. I crept up to the .1" DOC in small increments on subsequent passes. Speed and RPM were working great with no chatter, etc. Until it hit the middle of table it appeared to be in perfect harmony. Slowing things during the "slip" didn't make much difference.
.1" DOC in 1/2" aluminum with a roughing end mill climb cutting doesn't seem like to big of a cut for this machine. Again, it was cutting great with no issue until it hit near the middle of total X travel.
Today I was checking gibs. I put a test indicator on the edge of the table. Pulling the end of the table to me I was getting more than .015" movement. When I moved the table the measurement stayed. It didn't return closer to 'zero'. I tightened the gibs to where I could feel the table a bit tighter when moving Y and was able to reduce it to about .004". I could probably tighten the gibs more but I'm not sure what amount of movement is acceptable or normal.
I measured the backlash in the dials. Y is .007" and X is .013". I found this thread a bit earlier and I don't think it applies given how little backlash I have but I'm not sure what is normal for a machine like this.
Something tells me this could be leadscrew related. If it were the split nut I'd expect to see that throughout travel. I ran the table to either side of X and looked at the leadscrew. I ran it under slow power and looked for any chips, cuts, nicks, etc., and it appears to be 100%.
Could the Y axis gibs being out that much cause this? That's the only thing I've found that seemed out of whack.
