Thanks everyone for the suggestions, saw a couple of types I'd not known about. Budget is too tight currently to upgrade to anything decent. I've got to get a DRO on the mill - I had to suck 'scrapage' on 30 pcs a couple of weeks ago.
In hindsight I should have described the garage shop better. It's detached, 25x25x8 Ceilings. Wood siding exterior, 1/2" wafer board interior.
Ceiling is totally covered. So much so that I had to cut a section out to access the attic when there was a leak.
They put 6" of insulation up there, but as I found out when I re-wired the panel there's nothing in the walls.
Floor we've got covered. My Better-Half has snagged a bunch of decent (various) kinds of floor covers.
I've got it so packed now that I can't re-do the walls. A friend offered me a 3t heatpump that was on his 30x50 pole barn that he replaced with a 5t unit but I haven't gotten around to grabbing it. I also don't know how to install it properly. I would need to find some empty wall space and then the electric is a whole 'nother matter.
I had the 'jet engine' propane going when I made the post and when I went out to the shop the tank had emptied and the shop stank from that smell you get when you empty a bottle. I had a 100 pounder that an acquaintance 'borrowed' when his furnace crapped and never returned and I'm making do with 20 pounders.
I've got the 240v heater mounted 3' from the ceiling and it does a decent job when it's in the 30's - 40's. (Picture at end of post)
The thing that is getting me is that I can't keep my outer fingers and feet from getting chilled and going numb.
My father had some sort of difficulty with the same issue but alas I didn't pay attention when I should have.
And of course all that metal just loves to soak up the cold. So that gets to you hands and then if it gets too warm it starts to condensate.
I'm frustrated, trying to make some extra cash and I can't handle the cold as I could when I was a tad younger.
EXACTLY! can't find them anywhere. Some of those 'UGG' boots look doable with the flat soles for my bad foot, but all I've seen in the stores are for the gals.
Picked it up for $25 at an estate sale.
