I've been working on the compound. To get it apart I had to loosen the black lock ring. Seems like that holds the whole assembly together. It was threaded with acme threads. Once I got that loose the leadscrew came right out. After the leadscrew was out the brass nut slid out.
The dial seemed to be held in by a small piece of spring steel. It had an odd cut to it like it was broken.
Can I reverse plate the hand wheels then nickel plate?
The upper and lower parts of the compound are being de-rusted by electrolysis.
Sent from my SM-T813 using Tapatalk
