[4]
Surface plate question
[3]
[10] Like what you see?
Markinfargo
Newbie
Mar 26, 2018
3
I'm planning to add a surface plate to my shop. I'm curious about temperature effect on the plate. I'm in North Dakota, my shop is my unheated garage. Maybe I'm missing something, but what I've been reading understand as the temperature extremes that are in my shop will basically destroy the surface plate. Am I missing something? The shop I used to work in wasn't very well temperature controlled, and the surface plate there seemed to be fine, but then again, I didn't need to use it very often. Ideas? Recommendations?
benmychree
John York
Jun 7, 2013
3,137
The temperature will not hurt them, but possibly it may not be as accurate in terms of flatness or overall tolerences; in a hobby shop, it does not matter, I don't think you could tell any difference in ordinary work. You do not state whether or not you are talking granite or cast iron, if iron, you'd want to keep it oiled to prevent rust, I use a very oily rag under a wood cover on mine.
Markinfargo
Newbie
Mar 26, 2018
3
I intentionally left out the granite and cast iron comparison as both are viable options at this point.
benmychree
John York
Jun 7, 2013
3,137
Personally, I prefer cast iron plates, they are much lighter than granite, and I think that tools slide on them easier.
projectnut
Brass
Apr 14, 2014
603
My experiences are a bit different. Last year I was in the market for a 24"x36" surface plate. I looked at both cast iron and granite models. In most cases the cast iron models were heavier. I ended up purchasing a 24"x36" Challenge brand plate. It weighs in at 475 lbs. The same size granite ones were between 410 lbs. and 440 lbs.
benmychree
John York
Jun 7, 2013
3,137
I have a 24 X 24 cast iron plate that I can easily pick up and carry, try that with a granite plate ---
projectnut
Brass
Apr 14, 2014
603
I'd be interested in knowing what brand surface plate you have. I'm guessing it's not a Challenge brand. The 24"x24" Challenge cast iron plate weighs 325 lbs.
http://www.challengeprecision.com/products/plates/threepoint.htm.
Their Granite plate of the same size weighs 275 lbs.
The same size Granite plate from the CNC specialty store only weighs 216 lbs.
https://cnc-specialty-store.com/measuring-inspection/surface-plates/precision-granite-surface-plate-24-x-24-x-3-grade-a-or-b?gclid=EAIaIQobChMIuOq4he3b2gIV1xKBCh2dDwoxEAAYASAAEgJrKfD_BwE
One from Grizzly weighs 234 lbs.
Even one from Starrett only weighs 220 lbs.
benmychree
John York
Jun 7, 2013
3,137
I looked and did not see an obvious brand name on it, but will perhaps look again tomorrow and take a picture; the top is 1" thick, and the height including the top is 5 3/8".
[6]
[5] [7]
