- Oct 30, 2012
- 156
Some time ago (2016?) I stumbled on to some cheap (at the time) LED T8 bulbs in a Fastenal clearance rack that some stores have by the door.
These were Cree branded bulbs 18w, 4000 temp. Kind of oval shaped. I only got 2 of them. Then I found an AMZ warehouse deal on some other brand of a 5000k temp and I bought 4 of these.
Both sets of these are the type were you Remove the ballast and power only one end of the bulb with power and neutral. So, this necessitates non-shunted tombstones.
I used these lights to upgrade 3 of my shops 2-bulb T8 fixtures to LED. Using the 4000k and the 5000k in the same fixture side-by-side gives me a nice color balance.
Now that these LED upgrade bulbs have become much cheaper ($5 a light and not $15) I am thinking about doing the rest of my shop.
Question: Should I keep down the path of replacing my tombstones and disconnecting my ballasts (like Hyperikon for example) OR should I opt for some of the no-change bulbs that let you leave the ballast in place (like a Phillips brand)?
In other words do you think its important to keep my shop fixtures "The same" wiring wise for the sake of some poor soul down the road?
