- Oct 6, 2019
- 10
In making a tail support for my new 12 sided R8 collet block, I decided it might just as well double for a mill stop. I machined a 1.5" x 1" x 3" rectangular piece of mysterium steel to have a 60 degree conical tip to support extended work. I added a rod perpendicular through the back so that I could turn the assembly sideways and use the rod as a mill stop in other operations. The nuts on top and bottom of the "dead center" are to lock it into position. I cut 3/4" 16tpi so that one turn would give me 1/16 of an inch adjustments. The castle nut on top isn't for style points (though it did add a nice touch). It was the only other nut I could find in my pile that could be drilled and retapped to 16tpi.
