Taking the CNC Plunge
I'm at the point where I need to fire up the computer so I can configure and test the electronics. Before I do that I'd like some feedback on my wiring and initial configurations. Don't want any smoke to get out!
Some notes first. I left in place the VFD wiring for my On/Off switch, Fwd/Rev switch, and potentiometer. For those VFD terminals shared between manual control and Mach3 control I spliced the wires together. I'm still reading through the PMDX and ESS manuals and searching the net. Still have some configuration to do such as spindle pin assignment, ESS configuration, and more.
Here are my wiring and initial settings:
Drivers to PMDX-126 (J1, J2 and J3)
Step signal to Pin 8, 6 and 4 on J1, J2 and J3
Dir signal to Pin 9, 7 and 5 on J1, J2 and J3
Enable signal not connected
115VAC to PMDX-126 (switch set to "115")
Probe wire to J12 Pin 15 (ground is through spindle)
Limit switches to J12 Pin 11 (wired in series)
Limit switch ground to adjacent GND terminal
E-stop wire to J13 "E-stop" Pin
E-stop ground to adjacent GND terminal
JP1 set to Pin 1
JP2 set to Pin 14
JP3 set to OFF
JP4 no jumper provided
JP5 set to OFF
JP6 set to NORMAL
PMDX-126 SW1
Config 1 - Open (Off)
Config 2 - Closed (On)
Config 3 - Closed
Config 4 - Closed
Config 5 - Closed
Config 6 - Closed
Config 7 - Open
Config 8 - Open
PMDX-107 to VFD (Hitachi WJ200)
SW1 - all off
Rev/Dir to VFD terminal 2 (logic input)
Fwd/Run to VFD terminal 1 (logic input)
Com to VFD terminal P24 (+24V for logic inputs)
Aref to VFD terminal H (+10V analog reference)
Aout to VFD terminal O (analog voltage input)
Agnd to VFD terminal L (GRND for logic inputs)
Mach3 Spindle Setup
Disable Relay Control - Checked
Use Spindle Motor Output - Checked
PWM Control - Checked (I'm thinking this should be Step/Dir Motor based on my PMDX-107 wiring)
PWM Base Frequency - 25
Minimum PWM - 5%
Spindle Motor Tuning
Steps per - 1000
Velocity - 60
Acceleration - 5000
Pulley Selection
Pulley 1, Min Speed = 0, Max Speed = 8625, Ratio = 2.5
Pulley 2, Min Speed = 0, Max Speed = 1380, Ratio = .4
Thanks,
Tom S.
Step/Dir setting per your settings in Mach3
I don't use a probe so N/A
My limits are wired in parallel so N/A
E-stop "OK"
Power in is correct if using household current.
JP1 set to Pin 1
JP2 set to Pin 14
JP3 set to OFF
JP4 set to OFF
JP5 set to OFF
JP6 set to NORMAL
PMDX-126 SW1
Config 3 - Closed
Config 4 - Closed
Config 5 - Closed
Config 6 - Closed
Config 7 - Closed (position does not matter if JP1 set to pin 1)
Config 8 - Closed position (does not matter if JP2 set to pin 14)
My VFD is different so N/A but below is my setup for a Haunyang VFD for comparison
PMDX-107 ---> VFD
Pin 6 - Rev/Dir ----> REV (reverse run)
Pin 5 - Fwd/Run ----> FOR (forward run)
Pin 4 - COM (common terminal for relays, pins 5 & 6) ----> DCM (common terminal of digital and control signals)
Pin 3 - Aref (not used)
Pin 2 - Aout (spindle speed analog control voltage) ----> VI (analog voltage frequency reference input)
Pin 1 - Agnd (VSD ground reference) ----> ACM (common terminal of analog and control signals)
PMDX Config settings (dip switches)
Config 1 = Off (Normal Mode)
Config 2 = Off (Normal Mode)
Config 3 = Off (relays operate as for and reverse control signals)
Config 4 = Off (charge pump signal required)
Slow = On (fast PWM filter response) (Off setting caused some issues with my cheap Chinese VFD)
5v/10v = Off (10v reference)
Mach3 Spindle Setup
Minimum PWM - 5%
*Under "General" I set the spin up delay to 1 second longer than the spin up parameter in the VFD to make sure the spindle was up to speed before cutting.
Steps per - 1000
Velocity - 60
Acceleration - 5000
**Pulley Selection
**(I never figured out how to switch between pulleys in the software so I have pulley 1 as my high speed pulley. When I use the low range I have a tool library setup in HSMworks just for low speed tools and the speed is set to compensate for the speed reduction. If you figure that out please post how it is done)
I can email you screen shots of my ESS setting if you want to see them.
E-stop "OK"
JP1 set to Pin 1
JP2 set to Pin 14
JP3 set to OFF
JP4 set to OFF
JP5 set to OFF
JP6 set to NORMAL
PMDX-126 SW1
Config 3 - Closed
Config 4 - Closed
Config 5 - Closed
Config 6 - Closed
PMDX-107 ---> VFD
Mach3 Spindle Setup
Minimum PWM - 5%
Steps per - 1000
Velocity - 60
Acceleration - 5000
**Pulley Selection
Thanks for taking a look and commenting. Always good to have another set of eyes checking to make sure I didn't do something foolish. I finished up configuring Mach3 today. Just have to make a couple of changes you recommended and other than a couple of dip switch changes looks like I'm ready to power it up.
I would have thought I could find more info on wiring the spindle control board to my VFD. All I could find is one example of a Hitachi VFD and the PMDX-107 spindle control board. So that's what I used along with the PMDX manual.
Yes, please send me screen shots of your ESS configuration. No hurry though. Leaving for Oregon tomorrow to get away from the 110 degree heat. I'll get back to it in a couple of weeks.
Tom S.
For those interested here are a few pictures of my BoB, ESS and spindle control board installation.
A piece of 3/16" aluminum plate cut to fit into the 12" x 12" enclosure. 1" tall stand-offs for mounting the BoB.
115vac in at the top and control wiring (ethernet cable, motor driver and limit switch wires) in at bottom. Five 9/16" stand-offs for mounting the 3/16" plate.
The new electronics mounted and ready for installation.
The plate mounted in the enclosure and components wired.
Finished up installation and configuration of the BoB and ESS and have them working in normal mode. I can jog the motors, the e-stop works, limit switches do what they are supposed to do, and the probe functions. But when I configure the Dip switch for normal mode with charge pump (as suggested in PMDX Bulletin AN002) the motors no longer move and the remote e-stop doesn't work. I've enabled the charge pump function in Mach3 and specified Port 1 and Pin 17. Spent most of yesterday reading and trying to track down a solution. No luck!
My second issue is I can't get the PMDX-107 board to communicate with my VFD (Hitachi WJ200-015SF). I followed the AN002 instructions but still no communication. Tried it with charge pump and without. I'm definitely missing something in the 107 or VFD configuration.
PLC is jumpered to L on upper row "Source Logic".
Motor thermal switch to Terminal 5 (Logic Input) and Terminal L (Grnd for logic inputs) on VFD
107 to VFD Connections:
Rev/Dir to Terminal 2 on VFD (Logic Input)
Fwd/Run to Terminal 1 on VFD (Logic Input)
COM to Terminal P24 on VFD (+24V for logic inputs)
Aref to Terminal H on VFD (+10V analog reference and probably not needed)
Aout to Terminal O on VFD (analog voltage input)
Agnd to Terminal L on lower row on VFD (GRND for logic inputs)
Not sure what I'm doing wrong. Any help is appreciated. If more information is needed please ask.
Tom S.
Aref to Terminal H on VFD (+10V analog reference and probably not needed so I removed it)
Tom S.
Attached is the programming info Mark (MKSJ) sent me when I first setup my vfd. Worked perfect right out of the box. Keep in mind these settings are for controlling speed with an external pot.
I played with some of the parameters again this morning and had zero luck getting the spindle to rotate. The PMDX-126 pin 14 LED pulsed when I entered an "S" command so there is some communication between the BoB and 107 spindle board.
I'm stumped.
Tom S.
  • PM932 Mill Spindle motor programming parameters (1).doc
I'm stumped.
Tom S.
Hey Tom,
Your connections to the VFD look okay. What are the A001, A002, C001 and C002 setting in the VFD programming?
I would also double check the physical wire connections with a MM to verify the wires are good.
Hey Tom,
A001 is "Function F001 Setting". For reference the F001 setting is 0 Hz.
A002 is "Control Terminal"
C001 is "STA:Start Motor"
C002 is "STP:Stop Motor"
Thanks
I'm not sure Marks setting for C001, C002 & C003 apply to the PMDX-107
Try these settings:
A001 - 01 Control Terminal
C001 to 00:FW
C002 to 01:REV
I believe Aref is only used with a POT.
Try these settings:
C001 to 00:FW
C002 to 01:REV
I'll try your suggestions in the morning. I think you are right about Aref being used only for a pot.
Thanks
