- Jun 12, 2014
- 4,806
Combination chuck is a scroll with independent jaws on the scroll carriers. The smallest combination chuck from Bison is 8" and even if there was a 6", it would be way too heavy for this size lathe. I think the Set-Tru D1-4 6" chuck from PM/QMT offters the best value and performance, their Taiwanese chucks are well made. Anything else other than a Chinese mainland copy will be probably be twice the cost with a back plate. Please not that Set-Tru chucks are not for routine centering of work, they are designed to be set and left, they will repeat typically within TIR of 0.0004" or less for the same diameter stock. Is the spindle a D1-4 or do you have an adapter plate to a bolt on, if the latter the stick out for a small lathe will be a problem.
