[4]
Tap Storage Ideas
[3]
[10] Like what you see?
papermaker
Mar 12, 2013
302
I buy taps at my local used tool store buy the jar full. I hate having to dig through a pile of taps to find the one I need. I'm looking for ideas on how to store them in a orderly fashion.
Sharky
Jul 14, 2013
197
I use a scrap block of whatever is handy (aluminum, wood, plastic) drill a series of holes spaced about 1/4" spacing and drop the taps in by the shank, leaving the threading portion up. Arrange from small to large and you can get real close to your desired size with just a glance. I've tried to sort further, separate blocks for fine vs coarse thread, but that never stays sorted for long.....
Uncle Buck
Nov 10, 2011
0
Yup, just what I was going to say!
FanMan
Mechanical Hacker
Mar 14, 2013
352
I use those flat plastic divider boxes like some people use for fishing tackle. Each compartment holds one or more taps, tap drill (so I don't have to search separately for the tap drill), and die for a size.
24more
Feb 26, 2013
59
This is what I do also. Live not having to hunt down the proper drill.
bmw rider
Jul 15, 2012
72
I have my taps and dies in one of those little multi drawer parts cabinet; it's hung on the wall near my machines. I labeled each drawer with a label maker so I can find the correct size easily.
refinery Mike
Nov 3, 2012
97
I store my taps in the tall Plano boxes. about 4x6x 4inches deep. I drill a block of wood to put the top of the taps about level with the top of the box, for easy pickens. Then i built a small shelf on the bottom of my floor rafters to hold those boxes. When i need a tap, i reach up and pull down a box. Like they said i have holes in the block for the appropriate drill as well. And Plano boxes are made right here in the USA not China,
Somewhere i saw blocks premade that hold your taps. They had a tap, a tap drill, and a thread pass drill, right side by side and then stair stepping down for size. Might be a good idea.
David
Sep 21, 2011
299
This it the way I store most of my smaller taps. I have accumulated quite a few over the years and this method is convenient for me.
David
David
Sep 21, 2011
299
Just metal cans with screw on lid Pipehack. They have a cork seal in lid. Army issue maybe? They are olive in color! Acquired about 40 of them several years ago.
David
Pmedic828
Feb 19, 2013
220
I have recently purchased some 3 tap sets (taper, plug, bottom) and along with the appropriate die. I store them in resealable bags that my daughter uses for jewelry pieces. These are about 3 1/2 inches tall and about 2 1/2 inches wide - I placed a sticker on them as to the tap size, drill #, and major diameter for each size. That way, when I grab a tap, I know the drill size, what size to turn the blank down to to thread and also color coded the labels as to fractional, NC, NF, and metric. Maybe some pondering information.:think1:
gmcken
H-M Supporter - Silver Member
Sep 2, 2013
67
I have found that the small plastic storage cabinets with drawers work good for storing taps and extractors. You can make labels for the drawers or use a magic maker to identify the sizes. It will hold a lot of taps; #1 thru#12 and inch sizes as well. There is still room for the metrics.
Rick Leslie
Jul 30, 2012
480
I use discarded prescription bottles for the really small ones. Works great for drill bits too. Destroy the label and mark the outside with a Sharpie.
road
Mar 10, 2013
319
This is what I have set up.
The drill bits are on the left, labelled with the sizes and the measured dia. on each drawer.
The taps are labelled the same on the right with a coresponding drill bit in each drawer.
Some drawers have misc. stuff, like small tapping tools, drive dogs, mini milling cutters etc..
Dave Smith
Mar 10, 2013
1,080
I use the prescription plastic containers like Rick also--I also label them size and tpi and I keep a container of the same size nuts and a container of the small cap screws all together--it keeps me from hunting for the nuts and bolts after tapping--Dave
rdhem2
Sep 11, 2012
327
I am a little late with a reply but finally here if you are still interested. Tap storage has always bugged me as an old machinist once told me that to let taps bang against each other was just like allowing reamers to bang against each other. They get chipped and dulled. Good taps are expensive and cheap taps aren't worth having unless you like headaches. So as soon as my Kennedy tool chest set arrived I made this tray to sort my "taps in use". Taper, plug, and bottoming in all popular sizes and taper and bottoming in less used sizes. It is quick and easy to find what you want, and return to storage when finished. They are protected and at a glance you can spot what is NOT there. Never leave the tap in the drill box again. Downside is it is rather large and bulky. I seem to do a great amount of tapping so in my case anyway, the space spent is a good investment. Duplicate taps are separated and stored by size in a little multidrawer storage box.
Slots were cut on the mill with round end mills. After I cut the major length I deepened the cut about 1/4 of the length on the return. This allows me to touch the end of the tap and have the other end pop up for me to grab. Labeling was done with a hand held tape labeler. I cheated, as I started with a piece of prefinished plywood with a wood grain pattern salvaged from a cabinet shop trash can.
As you can see the tray takes up a little over half the drawer leaving room for tap handles, upper right-pipe dies 1/8" to 1", tap guides, "T" handles, a few ACME square thread taps and a small box of duplicate small taps. Also left in the drawer, but not shown, are several different charts and slip sticks showing recommended drill and clearance hole sizes. I always tried to keep it simple for my guys, so when screw-ups happened there were less excuses.
drs23
Jun 18, 2013
702
These are all great ideas. I need to make a move on coming up with something better than the resealable "Glad" container they're in now. I guess they're bumping into each other but I've had them stored like that for 10+ years and somehow they've remained sharp and usable.
savarin
Aug 22, 2012
2,050
I dont have any photos because an ex "friend" stole it Grrr!
I used 19mm thick by 300mm wide by 400mm long pine planks with the slots routed out to size for each tap.
A thin 3mm thick ply lid was hinged along one edge.
I soaked the pine base with engine oil until it was totally saturated as an aid to anti rusting. (very humid here in the summer)
When I get the time I will do it again.
itsme_Bernie
H-M Platinum Supporter ($50)
Jan 11, 2013
1,749
Holy crap that's fancy!
Bernie
burnrider
Mar 10, 2012
224
I cut small pieces of heat shrink for most the taps I don't use on a regular basis. Got the idea here from some one doing the same with reamers. Clear is best. Good for the hobby guys.
conibear
Mar 9, 2014
43
I store both my taps and lathe bits in ice cube trays, the kind that makes ice cubes for bottles. started keeping 1 tray beside the mill so bits ,edge finder, etc. don't roll off.
Glenn Goodlett
Active Member
May 22, 2017
45
I throw mine in a drawer. It takes half an hour to find the size I need. If I don't have the right size, it takes an hour to figure that out.
I need to do something.
[6]
[5] [7]
