Hello everyone, I have a 63 heavy 10. I'm looking for the really small bearings at the end of the cross feed screw. They are on the taper attachment. Does anyone know of a source for a replacement set or have any viable options? Thanks
I know this is the right one for the rear, I believe it is the same for the front.
edit: after thinking about this a little more, I remembered that the thrust plates that came with this bearing were too thick, I used the ones that were still on my lathe, leftover from the original.
