- Feb 11, 2018
- 48
Hello I have a 1963 heavy 10 toolroom lathe. The machine is in overall good shape for it's age. It has some play in the cross slide. When I use the taper attachment it starts off cutting straight then goes to a taper. Leaving a straight piece of material on my taper. The taper is rough also. About 2/3 of the way up the taper attachment angle plate the carriage bindes up. No problems when not using the attachment. What is going on? What should I look for? Is my play causing the problems? Any advice would be appreciated. Thanks.
