How are you guys holding a tap on your mills? Yesterday I was (attempting) to tap some 1/2"-13 and the tap would just spin before it got too far. Mild steel, 27/64 drill, 3 flute tap, Lot's for Tap-Magic...I first held it in a drill chuck with no luck, tightened it until I was nearly bending the chuck key, then mounted it in a collet again with no luck.
I finally just started the tap in the work, removed it and finished with a big tap handle.
SO again I ask...what is a better way to hold a tap in the mill? Different tap (2 flute), larger tap drill? Maybe the tap is a bit dull??
