Hey guys. Quick question. Can you use Tectyl 900 gun oil rust preventative for a cutting oil. My father inlaw has some he wants to get rid of and I was wondering if I can use it for cutting oil.
Hallo.
Yes my friend I know gun oil is for guns,but as you surely know many things are used for other things they are not intended for. So I thought just maybe it can be used for cutting too. Please don't take offense because of my reply.
The question is not if tapmagic works,it is if I can use this oil wich is available and seeing that I don't have guns to use it on, I want to try using it for cutting. But thanks for your advice.
You can use any oil you want for machining! How well Tectyl 900 gun oil works for machining????... I think you are the person that is in the best position to determine that. I would like to hear your results when you give it a try!
I would first find out if it is reasonably safe to inhale the smoke, I personally will not take a chance with it as cutting oil . you just don't know what additives they put in it.
Yes, first thing to do is look up a MSDS sheet on it, some of that military stuff can be made with additives that can not be safe for prolonged contact, not to mention a fume hazard from inhalation.
