What temperature will steel loose tensile strength? Let me explain. I use a moly coating for transmission gears to reduce friction on racing motorcycles. Part of the instructions are to bake the coated gears at 400F for 1 hour. I decided to apply it to the rear drive chain so I thoroughly degreased a new chain and coated the pins, rollers and side plates. My plan was to place the chain in my gas barbecue grill to do the baking process, checking the temp with an infrared thermometer. Long story- short, I got side tracked. Two hours later. I checked the temperature and the chain was 650F. The factory tensile strength is 11,500PSI. Will 650F weaken the chain that I should order a new one? Hope not.
